Has anyone added a towing hitch after?
and1939
12:33 PM
Windermere, FL, USA
I don’t have trailer stability control or any of that, but I was able to wire up all the lights to work correctly and I don’t get error codes. I used a Bronco trailer wiring harness. My point is, it can be done without running it through the Grenadier system.
Can you please share the details how you wired in the bronco wiring harnes.
Warren481
5:33 PM
I bought a stock unit and the UK IA dealer is adding the towing electrics and hitch for me. They say it's no problem to add it.
Warren481
5:33 PM
How much in total, they told me around £4000!
Less than half of that, but it's being put on before I take delivery of the vehicle. They said if I take delivery and then add it on (or anything else) that it works out much more expensive.
  • Sad
Reactions: CRH
Oscar3rd
11:33 AM
Texas, USA
We have the hitch and wiring ( as close to plug and play as you can get) thoughts?
Dokatd
11:33 AM
Dallas, TX, USA
Were did you wire up the bronco harness? Behind the tail lights ?
Wiring is done just behind the little removable cover in the back passenger side corner. There is a big plug there with nothing connected, that has all the necessary trigger wires.
Oscar3rd
11:33 AM
Texas, USA
Does it have brake controller capability?
It can be if used in conjunction with the
Redarc EBRH-ACCV3-NA Tow-Pro Elite Electric Brake Controller; as suggested by Mark @ Redarc.. We have not added this feature into our wiring set-up. Adding that feature will be forthcoming, but the INEOS Grenadier with factory trailer wiring would still have to have a brake controller such as the RedArc installed as it is not supplied from the factory with such.
