GrenX Upgraded Suspension System by Bilstein, Shocks, Steering Damper, Eibach springs, poly air airbags
GrenX
Supporting Vendor
8:38 AM
Melbourne VIC, Australia
GrenX just completed development on a full suspension upgrade solution using euro spec Eibach springs and custom designed Bilstein shocks with Bilstein steering damper & rear air bags by Poly Air. In stock now Australia.
If you would like to improve the handling of your vehicle with better steering response (less boaty) and improved return to center steering in corners then we got you covered. Will fit standard height vehicles, or paired with Eibach Prolift Spring for improved ground clearance and Polyair bags in the rear for increased load carrying capability.
Just been through the Simpson on standard suspension at GVM - but had to fit polyair airbags to lift the rear.
Interested in the lifted springs and ability to carry more. How much are the bilstein shocks - dosnt say on your website.
Thanks
Thanks
How did the poly airbags hold up. I’m interested in them for the same reason as sitting pretty low when overlanding and max weight.
They seemed to work very well. The ability to adjust them to keep the suspension at that point of balance between all 4 corners is great as the weight changes every day- fuel and water use etc. Don’t seem to impeded the sensitivity of the springs.
Thanks
Website being updated this week.
Price in $AUD supply only plus shipping
4x Eibach Lift Spring $1140
4x Bilstein Lift shocks $1730
1x Bilstein steering stabilizer $499
Rear Airbag system price coming this week
To be fitted with our wheel alignment specifications.
Thanks thats great. I will be looking into it.
Hi
Can yo help me out. I have bought the standard height airbags for my grenadier as I needed the support to get through the Simpson at GVM.
I want to get the lift kit you sell but want to also use my airbags… will they work together?
Thanks for your help.
Richard
