Well until my Grenadier arrives I can only dream of towing. But it's OK to dream, I've been doing it since the 60s
(Sorry if you don't do FB)
Looks greatWe went to Carfest over the weekend, a 500 mile journey towing our caravan, they are made for each other - this photo was taken when we got back, 19MPG and a breeze, such a great tow vehicle!
Seems you might not be the only one (from FB):
Have spoken with agent and they are "chasing it up" with IneosSeems you might not be the only one (from FB):
The maximum permitted length I believe, still easy to tow!Looks great
That's a huge van for only one axle
1600kg according to the specEuropean Vans weigh a whole lot less than OZ ones - that would be less than 1500kg I reckon.
A similar sized single axle van in OZ would go up to 2500kg no problem.
You must have checked off the box, no winch.
What replacement tongue did you getAround 3 tonne and 240kg on the ball... not driven far, in process of setting it up. Ineos tongue was too low and then too high when turned over. This replacement tongue is getting close.
Just a front one.You must have checked off the box, no winch.
Thats pretty impressive rear suspension sag on the IG if you have 240kg on the ball.Around 3 tonne and 240kg on the ball... not driven far, in process of setting it up. Ineos tongue was too low and then too high when turned over. This replacement tongue is getting close.
That’s a pretty impressive snorkel extension there @bakepl - you should be able to take that across the Wenlock.Around 3 tonne and 240kg on the ball... not driven far, in process of setting it up. Ineos tongue was too low and then too high when turned over. This replacement tongue is getting close.
I'm trying a Mister Hitch 001HD but will need to measure levels /weigh everything but looks just about right for my needs. Upside down it has a 31mm rise and there's enough room to fit a stone stomper bracket unlike the Ineos hitch. The lneos is too low in the normal position and then too high upside down for my van.What replacement tongue did you get
Yes need to get it all weighed to see how everything is going and importantly what I have left in the vehicle..Thats pretty impressive rear suspension sag on the IG if you have 240kg on the ball.
