Petrol/Gas GPF
6:42 PM
From what I understand, the B58 (gasoline/petrol engine) in the Grenadier comes with a Gasoline Particulate Filter (GPF), also known as a Petrol Particulate Filter (PPF). It is a filter in the exhaust system like the Diesel Particulate Filter (DPF) that comes in all modern diesels.
Has anyone owned a vehicle with a GPF? What has been your experience? Did you have any problems?
Thanks in advance.
Sounds like some time is warranted under the Grenadier examining the exhaust - I'm particularly interested in knowing whether there is an oxygen sensor after the GPF.
So the GPF is there to catch particulates from the combustion process from exiting the exhaust? But it regenerates, to clean itself, by heating up and burning away those particulates? Doesn’t that introduce into the air, what the filter was supposed to catch in the first place?🤔
So the GPF is there to catch particulates from the combustion process from exiting the exhaust? But it regenerates, to clean itself, by heating up and burning away those particulates? Doesn’t that introduce the into the air, what the filter was supposed to catch in the first place?🤔
No
Not that I know what I’m seeing (CAT/GPF), but no sensors after the CAT/GPF. There is a welded metal tube exiting the bottom of the CAT/GPF can that leads me to believe they are in the same can.
Is the US GPF monitored?
Would its removal throw a code?
Probably as it would not register being there/working. When blanking off a filter system on previous diesel vehicle (not euro 6 with adblue), it had to have the ECU rewritten to turn the dash light off
