Front Camera Warning Always on
Same problem with forward warning camera
Same problem with downloaded new map but unable to install
Does anyone with this problem- not have a winch installed?
Do all of you also find that at 9.5 km of warning lights the cruise control kicks out and can not be reactivated?
I have successfully updated my maps to the 24 new download
Very specific requirements on the size of the drive / formatting and file setup - then it runs and forwards camera is 100% more stable
All my warnings lights stays off - but then at 30 km travel my cruise control kicks off system and forward camera / stability controls and obstacle brake system lights come on - and can NOT be reset by pulling off the road and switching car off and on again
Car has to “ rest a while before warning lights can be reset / eg cruis controls and electric stability control gone for the rest of your trip
Any advice Please
These are the lights and warnings on
You might check (or have checked) that the trim piece around the ADAS camera is properly aligned. I had a situation where it was ever so slightly obscuring the camera’s view of the front hood /end of car, causing it to throw AEB disabled and other errors while still partially working depending on road conditions.
I find that a tiny amount of humidity in the morning will create enough mist on the windshield that the warning comes on. Goes away after 15 minutes of driving.
