Frame touch up
Global Grenadier 76
9:50 AM
Need some advice - was washing under the truck over the weekend. After cleaning up all the mud out of there I noticed a rather large exposed portion of the chassis. I’m guess in a rock chipped the powder coating.
Obviously it needs some help, any suggestions?
Is this powder coated? My experience with PC is it chips, and water capillaries under it. I'd rather have paint for objects that will take a beating.
My Grenadier is going to need some serious remedial work underneath once we’ve finished this section of our travels. The protection plates especially have had the sh## beat out of them 😂
Krabby I address this every year on my Tacoma since the frame was replaced under the frame campaign. My tacoma takes quite a beating and even though it has some underbody protection, the frame still takes a few licks, I address these "repairs" in the winter after my wheeling season is done. To do this I take the following steps:
-Use a die grinder to zap off the rusty spots making sure to go to the edge of where good paint is meeting metal (Do this with finest/ least abrasive allowable grit. If the rust is new and minimal, a coarse grit is not needed. But gouges in the metal will make getting down to the rust more difficult and a more abrasive pad might be needed)
-Clean surface with denatured alcohol until zero residue visible on cloth (I use white shop rags) and allow to dry
-Prime with Rustoleum Farm and Implement Grey primer (Brush on type, Not rattle can, for a heavy application)
-allow at least 24 hours to dry
-Paint with Rustoleam Farm and Implement Black Paint (Also brush on type for heavy application)
I have had great luck with this procedure and products holding up. The result of the paint being laid on heavy with a brush may not be aesthetically pleasing compared to a rattle can variant, but the durability is superior in my opinion...and its a frame, not a body panel 🤷‍♂️
I have a few spots on my frame, the fuel tank and sidesteps. So I did tons of research and landed on the following products:
  1. Mastercoat® Metal Prep & Rust Remover
  2. Mastercoat® Ultimate Permanent Rust Sealer SILVER Primer
  3. Mastercoat® AG111™ Ultimate Chassis Finish
Note: These are ALWAYS out of stock. You have to subscribe for email notifications and buy them as soon as they are available. And obviously sand as much of the rust as possible before applying products
