First puncture
8:15 AM
Well it had to happen some time couple of pieces of fencing wire in the KO2 rear OS so dusted off the jack tool kit and set to work . Did lock the centre diff and put it on low and used a coupe of rocks as chocks wheel came off no problem jacked worked as expected ( make sure. you have one where the handle bayonets properly into the jack get your dealer to change it if you dont) the wheel is quite heavy to put back onto the rear door mind your backs. Why didn't I use the Ineos recovery system or the ecall emergency button simple there was no coverage what use is the ecall with no coverage if there was a real emergency it wouldn't work what a waste.
DCPU
8:15 AM
I bet you're glad you swapped that jack now.
So no photos?
And tell me about your washers...
8:15 AM
Don’t have washers and no pics as thunderstorm was just starting and yes working Jack is a must
