Failure of central display
bemax
10:20 AM
Today the right side of the central display disappeared. no infotainment or camera. All menus are gone.
It’s still working technically because it shows a warning message „keep hands on the steering wheel“ or something else helpful when starting.
The left side with speedo, fuel and temperature gauge are there.
All (approximately) three minutes the whole display starts over again but the right side keeps missing…
I locked the car for 30 minutes and hoped the fault would be gone. Unfortunately I was wrong with this assumption.
Anyone here experienced a similar failure?
Best regards
bemax
First picture: missing right side of the display
Second picture: system restart while on the road
You could try the infotainment reset (with the vehicle on/running press the MUTE button until the whole display goes dark, then release)...
Definitely an odd one and it seems as though it is stuck on something in the boot sequence
I tried the reset you suggested. It seems to be the same reboot the car tries from time to time on its own.
It doesn’t work neither when I trigger the reset by pushing the mute button.
Thanks for the advice anyway!
To make it a little more thrilling the battery lost nearly all it had within 20 hours. Maybe the permanent reboot of the system drains it 😡
