Exterior replacement bolts / rusted
1:06 AM
Wilmington, NC
Does anyone know where to source some exterior bolts for the non-utility belt strips on the rear exterior strips (wouldn’t mind replacing the bump strip bolts too - just to get ahead of it)…Im sure I could contact my dealer, just wasn’t sure if there was somewhere online that people use?
remove It.. coat it in naval jelly to remove the rust, then spray it with rustoleum flat black…
The bolt on the passenger a pillar also slightly rusted on mine. I did the above…
I also cleaned up the rust and sprayed the steelies.
This is way less work than you chasing down those bolts
