Europe European recall on steering
Jean Mercier
GG#920
10:06 PM
Sint-Martens-Latem, Belgium
I was informed by another Grenadier owner of this:
Could it be the same recall as the North American one? Or is this different?
The description is different!
So does this refer to the joint that is particularly covered by the rubber boot? Also does this recall include the UK or is it just the EU 🤣
I would imagine it's the same as the NA recall requiring replacement of non locking with locking nuts.
"In early December 2023, INEOS became aware of reports involving two vehicles with loose steering rods observed. Separately, INEOS received a report related to a vehicle with a lost drag link during off-road driving. INEOS initiated an investigation which included an inspection of internal fleet vehicles. This inspectionrevealed one vehicle in which was installed a non-locking nut instead of a locking nut at the steering rod balljoint. INEOS then conducted an analysis of the screwing curves of vehicles with the locking vs. non-locking nut.Even though the non-locking nut had been torqued to the appropriate value, there was a potential for the nonlocking nut to loosen over time"
I would be interested what they call a locking nut
Many people think a nut with a rubber is a locking nut, but that is not the case. By using the wrong torque or if it is exposed to liquids or vibrations it still can get loose. The rubber only prevents that you lose the nut and after that more....The rubber gives time to recognize the problem without everything falling apart. A locking nut can't move, because it is secured by a sapwood or something similiar which prevents that the nut turns.
AWo
Balljoints used to come with castle nuts and split pins but it seems the plasticised locknuts are these days more the norm. Well that's my experience.
My UK spec Grenadier (delivered Summer 2023) has started making a creak/clunk from the steering column when changing suspension load. For example stopping straight line, then giving steering input as I accelerate while turning at an intersection. I’ve not been told by the company that my vehicle is recalled. Should I be concerned? Dealer is a long way from me.
Is it similar to this noise?
Get some parts changed out by the dealer now.
OP
AWo
Hi, so far I only new the “rubber locking nuts”. Let me share in layman’s words what I learned recently 😉
Had received a recall letter reg potential wrong nuts at steering. So had my Grenadier at the dealer for checking and service in April.
Dealer showed me two nuts: the “wrong” that might lead to security issues and the locking nut that must be used.
Have learned that such locking nut is compressed slightly before installation. So it’s a slight ellipse instead of a circle.
As the height of the two models is different dealer can easily check which one is used.
