DVA Mechanics
DVA Mechanics
Supporting Vendor
8:36 AM
Atlanta, GA, USA
Can we get a pic from further back? I'm wondering how far outside the "side wall" does the mini stick out after installation. Anything past the roof gutter would be no bueno for me since I want to use it in motion, and this looks way past it.
We finally got our Mini back! Here’s a photo that shows it exactly.
DVA Mechanics
Supporting Vendor
8:36 AM
Atlanta, GA, USA
Enhancing Your Ineos Grenadier: Mounting Traction Boards to the Rear Ladder Accessory Carrier
Embarking on off-road adventures with your Ineos Grenadier is all about preparation and adaptability. One essential upgrade that can significantly enhance your vehicle’s performance and versatility is the installation of traction boards onto the rear ladder accessory carrier. Here’s an inside look at how this modification can transform your driving experience.
DVA Mechanics
Supporting Vendor
8:36 AM
Atlanta, GA, USA
**Customer Photos**
A customer shared stunning photos of their build, featuring a blue Jerry Can mounted on DVA Mechanics side accessory carrier, perfectly matching their beautiful blue Ineos Grenadier with a factory Rhino Roof Rack. We love seeing our products in action!
www.dvamechanics.com
#DVAMechanics #IneosGrenadier #OverlandLife #AdventureReady #JerryCan #OffRoadAccessories #VehicleMods #OutdoorGear #AdventureSetup #BuiltNotBought
MrMike
9:36 PM
**Customer Photos**
How does the side mount go for lateral movement?
parb
5:36 AM
Silicon Valley, CA, USA
I got my rear ladder mount for hi-lift jacks.
Really easy to install (i put in a few drops of vibra-tite before sealing it up.
The thread for the mount to the hi-lift is M8 course. I used a bolt, put some 1 1/4 inch rubber washers between the mount and the jack, a flat washer and a lock washer before i tightened it up. When the jack is attached its super solid. When its only one attachement point, it rotates a bit. But overall i'm very happy with the mount. Good purchase and i think its very robust.
You can see here that i used too long screws. The hardware store was out of the size i wanted (35mm long) and i had to use M8 x 45mm.
DVA Mechanics
Supporting Vendor
8:36 AM
Atlanta, GA, USA
That looks Amazing!
So happy with your experience! It looks amazing!
DVA Mechanics
Supporting Vendor
8:36 AM
Atlanta, GA, USA
Would you mind if we posted your photos on our social media? :). Thanks!
