I truly appreciate this forum. Sorry to hear from those who experienced the drive shaft issues and hope a resolution is found. I’m having my lift undone for now. It’s not something I want to be worrying about on the trail.
What did Tom Woods say? I have had them on a older FJ and they are awesome!Yes... Haven't replaced it the second time yet. Trying to figure out my options and if I just need to go back to the original springs.
Have a call into Eibach. Reached out to a couple places about custom shaft. So far, Tom Woods can't.
In the Gren there are no flanges at the drive shaft's ends. So no possibility to increase the length here. Cutting & welding a piece of pipe in would work, I wonder if this is not a standard work for shaft repair shops: Cutting out a failed CJ & welding in a new one seems to be a similar job, and this is obviously done regularly.... If so, this could be solved with additional adjustiing plate between flanges on one end of prop shaft.
Has there been a full evaluation of the vehicle laden and unladen driveline working angles and lengths and the appropriate calculations including propeller/drive shaft working speeds?
For the first question, presumably Magna did this, or at least validated Dana's work. If the count of failed shafts in unmodified vehicles has got IA's attention then I expect they will be taking another look.A drive shaft company will make a shaft to suit anyone's needs but it still doesn't mean the component will have the long term durability and possibly cause other issues within the powertrain. A centre supported double cardan joint at each end may be one solution, but it is a heavy rotating mass that wears and at high working angles like any universal joint will wear quicker, will require more maintenance and have an increasing resonance as it wears. The other item not mentioned is the total voiding of the drive line warranty. Premature excessive wear to splines and gears in transmissions can be caused by frequencies induced into the transmission caused by poor driveline angles and excessively heavy shafts at speed combined with low engine speed in overdrive.
NVH for the consumer. The civilian 463 gwagons had a cv shaft between the divorced t case and transmission, that was a nightmare to swap when it would wear as it was impossible to service, and the military 461’s had U joints. Imperceptible in practice, but, on German engineer paper necessary for smooth operation no matter the service nightmare.So having had my prop shaft fail at the joint that I now know is a cv joint. I’m only acquainted with UJ’s
Why have Ineos gone with a CV joint on the prop shafts when from what I can gather on the internet they are not as robust as UJ ‘s . Do any other large 4x4’s go with CV joints on the prop shafts.
What’s the consensus regarding whether the failed joint is just an isolated bad joint or whether it just ain’t up to the job as someone mentioned in another thread. Interested to know your thoughts.
On the plus side we’ve all got five years warranty to work out whether the CV joints are a weak point so plenty of time to put lots of miles on the Grenadier and test it out.
To dig deeper, I think It’s the front leveling springs that are the major culprit. Stick to the flat 30mm and my guess street driving will be fine, with a shortened boot life.Dang, I guess I need to put any lift plans on hold.. I don't have free time to be dealing with drivetrain issues.
The CV joint is bolted to transfer box and differential unit. If this is not called flange, what it is?In the Gren there are no flanges at the drive shaft's ends. So no possibility to increase the length here.
The automatic gearbox is ZF 8HP70, or am I wrong?FIf this site is correct then 7th and 8th are both overdrives in the 8HP76 and 8HP50.
... due to the opposing angles of the transfer case and front diff nose.
They didn't want to fabricate custom adapters.What did Tom Woods say? I have had them on a older FJ and they are awesome!
I foresee “kits” that include new shafts in the future…Dang, I guess I need to put any lift plans on hold.. I don't have free time to be dealing with drivetrain issues.
4 days of moderate to light offloading. ~400mi or so.How long has this 2nd shaft been installed miles? any extreme off-roading to have the boots ripped that bad? Curious as I have only had my lift and tires put on 2 weeks now with about 200 road miles.
you took much better pictures than I did. Any chance that you can send them to Eibach? The ones that I sent them (per their request) were pretty poor.So after I got off of work yesterday I figured I should give the CV boot an inspection on the front drive shaft after reading though this thread. This is what I found now after only driving about 200 miles since I installed the Eibach lift Part # E30-34-001-06-22 and 35"/12.5/R17 Toyo tires. Caster settings were adjusted down to 1.5degrees as recommended from the 2 nominal, but this still wasn't enough apparently to prevent CV boot failure. See pictures belowView attachment 7868371View attachment 7868372View attachment 7868373View attachment 7868374
