After a bit of use the high low shift and centre diff lock go in and out quite easily but still a little clunky as was the old Defenders. Have not had the need yet for back and front diff locks so can’t comment on that.
So are you still unable to enter low range mode when you got home?Unfortunately today I entirely failed to be able to get mine into low range. I have had in kow range with centre diff unlocked before and it went in quite easily but today I could lock the centre diff but no low range. This is potentially a big problem, i was on atrack with some pretty knarly bits and there was some risk that I could get stuck, unfortunately that also means that there are no fromt and rear diff lockers available to you either because INEOS in their wisdom have made it a condition of use to be in low range. Fortunately the car is impressive enough that it managed even some quite knarly bit in high range with centre diff locked. I also had shovel, Maxtrax and winch and recovery gear if it came to that. But a bit bummed about this, tried all the tricks mentioned in this thread but nothing worked so I guess it’s off to the Agent to lool at it.
No can’t get into low range, literally can’t apply any more force, it just isn’t going to go. Don’t know why, will take it to agent next weekSo are you still unable to enter low range mode when you got home?
Is it the cable?
Someone needs to get the innards posted online.No can’t get into low range, literally can’t apply any more force, it just isn’t going to go. Don’t know why, will take it to agent next week
@DCPU was an animation somewhere of the transfer case in action. Maybe not quite what we're after but....Someone needs to get the innards posted online.
sorry to hear that, sounds like something has come amiss down below. mine rarely goes in unless the wheels rotate, a cm or two is usually sufficient to hit home. mine seems far from ideal. High and low un-locked are positive from the get go and once wheels rotate the lever seems very solid, same for Low locked. High locked however seems vague whether selecting or selected and rolling. All a bit 'off'. I got the awful grating sounds twice on the second day of operating the lever so I'm always very wary now. It's not like you can feather the clutch to 'test', you are all 'in' with automatic and then have to try not panic and find N or P.No can’t get into low range, literally can’t apply any more force, it just isn’t going to go. Don’t know why, will take it to agent next week
Latest news on the range change front: I drove back from town (about 5 minutes) and on a whim, tried to get into low range. It was not exactly easy, but I was able to get smoothly in and out half a dozen times. Drove 10m and...it wouldn't repeat. Anyway, I live in hope that it will eventually decide to cooperate. I'm treating it as a win!
Hi Guys, I just got a delivery 2days ago and today tried to put her into off road mode. then encountered the same problem described here. I rolled a car a little, but the same result. so I wonder how you guys solve the issue. any suggestion/advice are welcome. my dealer is 330mile away, hoping a solution without visiting them..Unfortunately today I entirely failed to be able to get mine into low range. I have had in low range with centre diff unlocked before and it went in quite easily but today I could lock the centre diff but no low range. This is potentially a big problem, I was on a track with some pretty knarly bits and there was some risk that I could get stuck, unfortunately that also means that there are no front and rear diff lockers available to you either because INEOS in their wisdom have made it a condition of use to be in low range. Fortunately the car is impressive enough that it managed even some quite knarly bits in high range with centre diff locked. I also had shovel, Maxtrax and winch and recovery gear if it came to that. But a bit bummed about this, tried all the tricks mentioned in this thread but nothing worked so I guess it’s off to the Agent to look at it.
A fair point, I'd describe it as moving in straight lines , side to side or down and up (not dragging across the centre), but if the box is never able to select low range with all manner of doing it when rolling at slow speed, uphill, downhill, in neutral, in park, then all the bings and bongs start (saying gearbox problem) then it probably wasn't right at the start. As I say, they changed the transfer box, probably correctly fitted the tensions on the cables and with a bit of 'use' it works. There are people out there who are trying to use a LOT of force to change the range, or select the centre diff. It shouldn't be that hard.Incase its not clear to people, the shifter moves in a box pattern. It doesn't matter if you go clockwise or counter-clockwise when you are going from high to low center lock or no lock, but you must move the shifter along the edges of the "box", not diagonally or through the middle.
In my case I had to get a new transfer case.Hi Guys, I just got a delivery 2days ago and today tried to put her into off road mode. then encountered the same problem described here. I rolled a car a little, but the same result. so I wonder how you guys solve the issue. any suggestion/advice are welcome. my dealer is 330mile away, hoping a solution without visiting them..
My advice, before you drive the car away from your dealer, especially if it's far, at least have a try to select low range or have them do it. Likely it will be on the parking lot and not gravel or mud so don't go ripping it up... but at least have them show you it can be done without a crazy arm wrestle...
Matt
I hear what you are saying but I can't understand why?I've found if you turn the engine off high and low engage easily.
