Cup holder.....
Can someone please measure the opening of the cup holder? Wanted to see if a 3 inch tumbler would fit. Many thanks!!
I can confirm this one fits. 20 oz traveler tumbler from Yeti.
… and one more, may not be for everyone, but it’s my daily coffee mug that fits perfectly. Only 10 oz. American but lived in Australia and a small Flat White is perfect in the morning.
Has anyone come up with anything that makes the factory "cup holders" anything other than completely worthless and a waste of space? Seriously, what coffee mugs do they use in europe? Do europeans drink liquids? My smallest travel coffee mug barely wedges in that stupid hole. While I'm at it, has anyone come up with something that adds cup holders for the rear passengers?
There are around 6 sizes of coffee cups if you exclude piccolo - 6oz, 8oz, 12oz, and 16oz being the most common and what most car brands select. The ineos seems to be good for 8oz or 10oz. There are hundreds of adapters out there that adapt any holder for your preferred cup size, whether upsizing or downsizing. I guess no brand has come up with the perfect cup size for every customer. I drink a 6oz cup size so have put two coasters in each of the cup holders which raised the cup bottom by around 1.5 cm - 1/2 inch which is just perfect for my coffee and the wife’s too. Easy to adapt /customise and many hundred products out there to fit for EVERY choice.
My family made me a brilliant Father's Day cup, with pictures of the kids on an alloy body. Sadly, the Grenadier is the only vehicle of the 3 I use where it does not fit... nor does it fit a 1L water bottle but my DMAX does!!!
it is a bungee cord. I had this mug mounted to the grab handle of my G wagon. The cord and the wooden stick worked wonderfully and I had it always at hand. You can see it in this picture (of a healthy diet) in the Background. View attachment 7841827
A g class professional…. Nice taste my man . How does it compare to the gren ?
I have been working on my version of the perfect "American" cup holder this week. I make a mug of coffee (latte actually) every morning and the stock holder is not up to the job. Instead of replacing the existing cupholders I decided to make a pair of larger diameter cupholders above them. After a few iterations I am pleased with the 3D printed version here.
It comfortably holds up to a 3.5in (90mm) diameter cup/mug above the original console surface, but allows a smaller diameter (like a can) to fit down inside the original cup holder on one side. It mounts using the 4 socket-head screws that retain the original cupholder.
This design leaves enough room to comfortably get your fingers behind the cupholder to allow easy access to the center armrest cubby release. I also included a pen holder (just a hole), which is more practical than it looks.
Interesting detail: Some of the straight and flat edges of this vehicle are not straight or flat. The console top surface is a slightly convex face and the sides taper very slightly towards the rear of the vehicle. Nothing in modern automotive design is as simple as it seems at first glance.
Let's hear some ideas for improvement.
If there is interest I will get the STL file posted somewhere on the forum so others can print one of these.
Like the others, I definitely would love to get the STL file if you're willing to share. It would make the cup holder so much more usable!
In Australia we drink proper coffee in normal size volumes
I personally only drink high quality espresso.
I usually have a water with ice in it in the Grenadier however.
They make them with a reduced size base to fit in cup holders. They keep the water cold for hours.
You could also put American cawfee I guess.....although not really sure why anyone would drink it.
Yeti standard 20oz tumbler fits as well
The STL file is now available for download in the Resources section of this site, under the newly-created "3D Printed Parts..." category.
Here is the 3d file of the single-cup version. Print and use as you like.
This is a great design! You can now post it to the new "3D Printed..." category of the Resources page of this forum if you are willing to share it here.
further to this, once submitted the resource is waiting for approval (this is to stop spam) and then it will go live. there will also be a thread automatically created in the following forum
Easy, check Amazon for multiple drop in options that allow for larger drinks and water bottles. Unfortunately you can only add one because two will not fit sitting next to each other in the Grenadier's present euro cup holder set-up. It should and will be an easy aftermarket fix since it's a simple, unscrew and snap out piece that's fitted there now and can easily benefit from a larger diameter cup holder unit upgrade but I also expect that Ineos will upgrade this item in the future providing us also with an easy drop in replacement for our cars.
