Cracking noise coming from the rear door :-(
inky_black
5:19 AM
Deutschland
I've had a cracking noise coming from the rear door for a few weeks now. This weekend I started troubleshooting and removed all the attachments.
Yesterday I had help with troubleshooting.
While driving it continues to crack, my help then pressed against the door with his legs and the cracking stopped.
Has anyone experienced this before and does anyone have a solution?
  • Sad
Reactions: IGL
Heard "noises" from the rear door area and discovered that the plate which anchors the gas strut to the cargo floor was loose! Tightening the plate fasteners cured the noise. Check also the door latches and whether they need to be adjusted to provide more compression on the door seals when closed....
Thank you very much @DenisM , I looked for it, unfortunately it wasn't. It still makes a noise.
@IGL This is not so easy to identify. The pressure was exerted on the separating point of both doors. Then it was quieter during the ride.
Do you have any other ideas?
Update: The error has been fixed. See text.
We went for a test drive and pressed the doors while driving, the noise was gone while the pressure was being exerted on the door.
My Ineos is currently being serviced and the problem has been fixed by readjusting the door. I got a new rear door seal not too long ago. The new seal meant that the door only ever latched in the first position of the lock but not in the second fully closed position. I did not notice this immediately after replacing the seal because the new seal had not yet settled. In the meantime, the new seal had settled and the door was always in the first position of the lock and had play, the door was virtually never closed properly. Now the lock catches have been readjusted and the door closes completely again, the cracking while driving has been eliminated.
Best regards,
Inky Black
Update February 2025: Problem has reappeared, Ineos has not found a solution for months
The noises reappeared at the end of the year and I went to my trusted workshop to carry out intensive troubleshooting. The noise has gotten worse and worse. It occurs during normal driving with the slightest twisting of the bodywork. In fact, it comes from the large rear door and can also be reconstructed by exerting pressure when stationary. The current assumption is that it is due to defective welding points on the rear door. I and my garage have already been in discussions with Ineos for nearly 3 months to finally obtain approval for a door replacement. Ineos is currently refusing to comply and is demanding that my agent carry out extensive investigations in their workshop. The customer is suffering from the problem and the lengthy processes at Ineos. It is not yet possible to estimate how long it will take until a door can be delivered. It is frightening that no stock is available and it is not clear when it will finally be available again. I am curious to see when this problem will finally be solved.
Keep your fingers crossed.
Best regards,
Inky Black
