Canoe and kayak mounting
CrazyOldMan
2:58 AM
Wisconsin, USA
What have you all ended up doing for canoe and kayak roof mounts? I have the Leitner HD load bars with standard T slots - Leitner also makes load stops so I’m thinking that’s the way to go with straps, but was interested to see what everyone else was doing. I’m specifically interested in canoes - 35 lbs is easy to load compared to my Alu-Cab awning!
For our double kayak , I've installed a rear roller , and made my own retainers from shelf brackets, padded with plastic pipe.
Only photo I have at the moment. To the far right you can see a 17ft canoe on my Gren, strapped to the factory Rhino rack.
Do you have brackets or load stops or something like that on the Rhino bars? Any concern about fore/aft slipping? Here are the Leitner load stops
No load brackets, but I do use load brackets with rubber pads on Yakima/Thule crossbars. On the Gren the canoe is secure side-to-side by the straps passing between longitudinal rack supports. If the trip is long or bumpy terrain I put rubber pads at the canoe/rack contact points and also attach bow/stern lines.
Where do you attach the bow / stern lines, or do you run it under and through? The Leitner bars come with a rubber gasket on top of the bars.
Rear to the hitch, front to the recovery points (bridle). I typically have to adjust the canoe position so the front lines do not contact to hood/bonnet.
I have used strap anchors with other cars. You clamp them under the hood and tie your bow lines to it. Never used it on the grenadier but i cant see why they should not work here too.
Yeah I was wondering about that - under the hood vs recovery points - or if you guys had seen other clever options. Obviously I want to avoid strap rubbing - but a trailer seems like a total waste and PITA for a canoe less than 40 lbs - even though the Grenadier is pretty tall. It seems doable.
For those in the US who are interested - Canoecopia (“the world’s largest paddlesports expo”) is in Madison in about 3 weeks.
You have no roller in the back. What's your technique to get them up there.
It’s only 16.5 kg- and the Leitner bars stick up 5 cm and are 25 cm from the back of the roofline. There’s a rubber gasket on top of the Leitner bars. I THINK with a tandem canoe I should be able to push it forward without rollers - but not positive. I think that I can just push it far enough forward to hit the tipping point / center of mass - and then step up on the bumper to push it all the way forward. I know people with Sprinter vans use those tipping rails with sliders, but I don’t think that would be necessary on the Grenadier. I’m not sure - just thinking about it and wondering if people have experience with it before I fork over $8k on a canoe. I just REALLY would like to avoid a trailer.
I just lift my 17ft canoe from the center balance point and walk it up on the rack. It’s only 70 lbs.
Late 90’s Mad River Royalex. So yeah, beefy, but 1100 lbs. payload. Probably should sell it for a lighter boat.
You can get 1100 lbs payload in a Swift Prospector or Keewaydin - at half the weight. Canadian Black Magic and Dark Arts at work.
A very small electric winch on the front of the rack connected to the ext roof outlets would be very helpful. I just could not find one.
lol.. 30 years ago my father put a small winch on the front of a van roof rack, and tugged his small pontoon fishing boat up a couple sections of pipe. worked like a charm.
