Camping table rattle
Skydance
7:51 AM
MANCHESTER
For those who are interested. Here is my tip to get 100% rattle free Ineos camping table. Tried and tested over 6 months. Assuming the table is fitted correctly and tightly, it still rattles on bumps. Here is a few photos of the things I’ve done.
So basically the arms rattle against each other. So fitted anti rattle tape to these areas and also a rubber washer/any washer behind the rubber stopper. Hope it helps.
Mine was rattling a little because a few of the bolts came loose. I tightened them and no problems since. Nice and tight :)
I found the spacers had a gap that was too wide. I'm not sure how they were supposed to be installed, but the gap was wider than the metal of the table, so it could never be tight. I flipped the spacers around so the little end was up against the door. That fixed most of it.
When that was done, I thought it was still rattling. After some more experimentation, it was the jack. A little tape on that fixed it.
