Australasia Cable for trailer electrics
11:16 PM
I have just picked up my grenadier and don’t know how to link the vehicle’s trailer electrical socket to a standard Australian trailer. Does anyone know if a cable exists that will plug into the grenadiers socket and into the trailer socket. Thanks
congrats on your Grenadier!! :)
what sort of socket on a standard Australian trailer were you envisaging ...a flat 7 pin, round 7 pin....
Adapters seems to very between A$70 -$100+
I recently bought one of these for $29 delivered https://www.ebay.com.au/itm/2737986...d=link&campid=5338980679&toolid=20001&mkevt=1
I normally assemble my own adapters, but in this case it wasn't worth the effort the ($29) price. The quality of the one I bought is very acceptable...
Thanks for the info Denis👍
There is a 13 pin to 7 pin large socket available, I am going to try the Land Rover Discovery 7 pin large to 7 pin small, that works alright with my existing trailers. I will get to you on the results😀
The Redarc trailer parks go in pin 12, I am waiting on the correct socket from Element14, Redarc do supplier the completed kit including wires and cabling, make sure you get a 2 or 3 metre cable for the dash to controller cable.
I still have not found the correct position to pick up 12vdc power supply for the Redarc, I belive its near the main left handside underseat fuse box!
I bought 2 cheap ones. Both had diodes in backwards which caused me no end of grief.
Personal recommendation is the Narva one, it works a treat on my car.
X2 for the Narva adaptors. I rewired one so the pin 9 power wire goes to pin 2 on the flat 7 pin plug as my cub camper Redarc BMS uses this as a signal to start charging when the Anderson plug is connected.
cheers Steve
I recently bought one of these for $29 delivered https://www.ebay.com.au/itm/2737986...pid=5338980679&customid=&toolid=10001&mkevt=1
Thanks Denis, just bought 2. (1 to keep as spare). The seller has many great reviews.
Hope this helps - Narva standard, yet each state may slightly vary.
Provided you trailer is wired to Australian standards, its plug and play with a Narva adaptor, which is wired up for electric brakes on pin 12 and combines the seperate clearance light circuits with blocking diodes.
If you have a large round 7pin pin plug on your trailer be VERY careful with ebay adaptors as the same 7 pin plug is used in Europe/uk and is wired differently, with seperate circuits for left and right clearance lights and no electric brake circuit.
The latest edition of my manual has all the information for Australian users.c
Cheers
Steve
Cheers
Steve
Can’t say I had complete success with the narva 13 pin euro to 7 pin flat adapter. Hired trailers last week. First trailer was bigger including the light set being bigger too and worked mostly fine. A couple of times had a minor flicker of red warning bulb seemed to sort itself out without intervention.
Second trailer was smaller and had a small LED lights setup - indicators worked on trailer, fine, but brake lights didn’t and caused trailer bulb failure warning to appear on the Ineos dashboard.
So not 100% compatible for me.
I gather there’s a pin that needs to be redirected to another on VW /Audi tow balls to make them suitable for Aussie wired trailers and to be recognised as properly connected by the vehicle electrics. I am assuming that the narva doesn’t do this hence the errors especially on a smaller LED light set maybe? Or just wrong resistance for LEDs? Or has my vehicle not been coded to be Australia trailer spec wiring - which I gather was a problem with VW Touareg for a while till VW released an Australia specific coding to set up for the tow ball.
Anyone had experience with this?
There is sm
There is trailer wiring info in the Rok Dr Guide, worth taking a look to see if it helps you.
My first thought is that there are some poor electrical connections on the trailer side and/or LED resistance issues, rather than a fault with the adaptor or vehicle wiring. Its not uncommon to see electrical faults/quirks with hire trailers, particularly those from garden centres that have a hard life. I have had similar problems is times past with my box trailer and the Disco 2. In the end the trailer needed a visit to the auto sparky to fix a couple of poor quality wire joins.
From memory the only change that Audi/VW made was the pin they used for the electric brakes on their 13 pin socket. I vaguely recall they re-purposed pin 2 (rear fog lights) but don't quote me. I don't know if they made vehicle side wiring changes specific for the Australian market, but it's possible. Tow ball and hitch receiver compatability/compliance is another issue. Also when the 13 pin plug first appeared in australia a decade or so ago there was a learning curve to determine compatability with Australia wiring standards hence the apperance of adaptors. Its all pretty well understood now. As @TheDocAUS said have a read of my manual (link below). Section 11 and appendix 3 have a lot of info on trailer electrics.
Cheers
Steve
https://www.theineosforum.com/threa...nofficial-owner’s-manual-supplement.12415655/
