If it would be an offical option fom INEOS it would increase their fleet consumption.IG should have really offered a 285 KO2 option
You sir are correct. Mea culpa. I just went back and looked at what I entered into the convert site and I used 285 75 17. The 75 makes it 33.8.FWIW : Actually it's only a 1"difference...31.6" vs 32.7" (https://tiresize.com/comparison/) so that at 70mph on 265/70/17 tyres, the 285 size speed is actually 72.4mph.
Load rating E:Anyone know what "load rating " the K02s being delivered are? LT265/70R17 121/118S but doesn't say if it is LT265/70R17/E 121/118S or a different rating..
Don't know if this helps, but on all my new vehicles I run a speed test using at least two sat navs (Garmin and TomTom).FWIW : Actually it's only a 1"difference...31.6" vs 32.7" (https://tiresize.com/comparison/) so that at 70mph on 265/70/17 tyres, the 285 size speed is actually 72.4mph.
Do you mean an additional 5 MPG between the two tire options?really wonder how much savings one might get from the stones to the bfg. humor me here. unless the IG is cast iron and the weight and tread of the tires won't matter, the stones should get better milage.
could you say up to 5 more? that savings will add up at the pump. do the math and get back to me on yearly savings. tell me you. can save almost 100
Really need to see it with some axle articulation...
Yea, that front clearance isn’t confidence inspiring, and with some weight in it…Really need to see it with some axle articulation...
Every manufacturer will spec the Bridgestones if they could pick up 5mpgI believe he does, sounds like a massive bridge too far to me.
There are several tyre manufacturers' references where they estimate 'aggressive' A/T and M/T treads increase fuel consumption by around 15% compared to a high efficiency H/T tread....
I haven't seen one but he did do a 20 minute video with a opinion piece walk through. He does a comparison to his new LC200.Is there a video?
