How did you get the light out? Thanks!Update: multimeter confirmed blue is positive.
Plastic pry tool to get started then used fingers to pull light out.How did you get the light out? Thanks!
Thanks for the explanation: gives me some ideas how to bring some light under my boot cover. Future project, maybe!Done and tested! Opening doors triggers the light. Will try it out when it gets dark. If it's not bright enough, I can double the output with a second unit.
@Jean Mercier , de rien! It's 12v.Thanks for the explanation: gives me some ideas how to bring some light under my boot cover. Future project, maybe!
What is the voltage feeding that roof light? 12V or 5V?
At first glance I thought this was a cool photo of a collapsible blender (Margaritas on my mind?)I have the same issue.
I bought a NEBO GALILEO AIR. I can use it in the back and easily take it to a table outside, without the drama of wiring it up. It has various power settings and a Red light mode. You can even hang it from the rear roof shelf, by installing a hook. I will not be mounting an LED light strip on the shelf now - problem solved and it is more versatile.
Thanks to Ronny Dahl's video for the idea.
This one...Which light did you go with?
The light is not exclusive to Teralume, I saw the same thing at US shop - but cannot I remember where. I have also seen it under another name at Offload Systems in Sydney. So you maybe be able to get it in the US, with less freight than from Oz.This one...
https://teralumeindustries.com/prod...our-x-strip-light?_pos=2&_sid=5eaebf357&_ss=r
Longer and shorter ones are available...
X-Strip Lights
Introducing the X-Strip LED Strip Lights: Dimmable, 5000K and 3000K Dual Colour, Waterproof, and Backed by a 5-Year Warranty with Integrated Buttons. Experience ultimate lighting versatility with the X-Strip, featuring both white and amber colours to suit any setting. With integrated buttons for...teralumeindustries.com
The one I saw at ORS was not Teralume, I looked.I asked Teralume if they had a US distributor. They said they didn't so I ordered directly from them. Would be good to have a US source of a similar light, though.
No worries. Doesn't have to be Teralume. Similar functions and capabilities are all I need.The one I saw at ORS was not Teralume, I looked.
