Bolt Pattern
1:49 AM
California, USA
Hello. Does anyone know the bolt pattern for the wheels? I know it’s a 6 lug but not quite clear on the 6 x ?? Starting to look for aftermarket wheels like Black Rhino and just want to make sure I find the right size.
Thanks!
Its on here somewhere, but if i remember correctly its 6x130 pcd?
Someone posted this info, reportedly from the Ineos rep for Australia:
The offset is 55mm positive. Hub PDC is 130 & hub threads are 6 x M14x1.5. Bore is 84mm.
Does anyone know the width of the stock wheels? I'm guessing it is 8 inches - that would make the most sense for a 265/70 R17 - but that's just a guess.
Steel wheels are 7.5 inch wide and the alloys are 8 inch
Just curious where you found this info. I looked through the U.S. brochure and did not see it. I'd like to know if I am missing-out on an available resource. Thanks in advance for your reply!
Steel and Alloy 17" are 7.5"
Steel and Alloy 18" are 8.0"
Thank you! Where would one find this information? I've gone through the UK price list, and the U.S. brochure, but I don't see this info. Maybe I am overlooking it, or perhaps there is a "specs" page on the website?
I asked the regional aftersales manager for the UK, Middle east and North Africa.
