Bison-Gear: Interior rear doors Molle panels installation???
LAdrummer
12:08 PM
Los Angeles, CA, USA
My Bison-Gear molle panels for the rear doors (interior) arrived today with no installation instructions. I am hoping someone here has installed them and will be able to tell me how I can install mine. So far I’m at a loss and I like to think of myself as resourceful and mechanically inclined but with these panels and their fiddly bits have me stumped.
Thanks in advance.
Thanks in advance.
There are installation guides on their website, "attachments" in the product details.
Just installed mine. A tip is to use a piece of cardboard wedged behind the U shaped 'clamp' parts to hold them in place while you're fiddling to get the screw and flange nut set. snug the fastener, then remove the cardboard before final tightening. This is mostly for the little door panel since the mounts are on the vertical edges.
LAdrummer, can you post pics how you installed them, I can’t read polish
Unfortunately I don’t have pics when I installed the Molle panels a few months ago. It was tricky as I’m sure you are aware. I can tell you to start the clip at the corner of the interior plastic panel. I lost a clip inside the door but was able to unscrew the plastic door panel a bit and the clip fell right out…luckily. After this snaffoo I used blue painter’s tape adhered to the clip to hold on to it as I pushed it in place. If I recall correctly I also used blue tape to hold the clip in place to the window as I screwed the molle panel to the clip. It’s hard to write how exactly I installed the panels. It sure does envolve a lot of fiddling. Good luck.
