BFGOODRICH ALL TERRAIN T/A KO2 LT285 /75 R17 121S E1 RBL
10:20 PM
North Texas
Looking to add these subject tires after delivery. Does anyone have insight if these will rub anything without a minimum 2.0” lift (spring or spacer)?
I suppose if I did install these while awaiting availability of a lift I could adjust the front turn radius bolts To gain some rub clearance.
Insight is much appreciated.
Thanks.
Someone posted a photo of a German (I think), Grenadier on 285/75s (34"s)... I think it was white, but no further information on it
Thanks.
I'm genuinely puzzled at why, in the absence of actually owning and experiencing the vehicle with the standard KO2 tyres/tires you are already deeming it to be in need of larger treads plus a suspension lift?
FWIW, Kenyan_Grenadier on YouTube has 285/70/17 MTs on his IG and says it works fine without any mod. Not first hand experience, but you can check it out.
I have a set of these waiting patiently for my gren to arrive. They should just go straight on.
likewise. MT on pre-order 285/70/17. I can't see the 285/75 option in BFG km3. was thinking about the 33/12.5/17
Can anyone verify if the
BFGOODRICH ALL TERRAIN T/A KO2LT315 /70 R17 121S E2 RBL
is a fit without any suspension changes, hub spacers, cutting of wheel well?
Seeing the fit of the 37” Toyo tires on the IG from Iceland make some believe it can fit ? Possibly the steering stops will need to be adjusted?
I understand this may be something I have to experiment with after delivery.
Thanks!
One of the few bonuses of having the wheel on the back door. A mate just put 34.something” Geolanders on his Nissan Patrol and now can’t get the spare wheel/tyre to fit under the vehicle. 😢
Im not sure if the mini door will open by itself with bigger tires...What size that is im not sure, but at some point the bigger tire will get in the way of the mini door.
Black sheep did 285/75/17 with a 60mm Eibach lift (only shocks and springs) and no further modifications. They developed an adaptor for the spare wheel to clear the rear small door. I’ve got a video on my YouTube detailing what they did.
Subscribe, share, support :)
I recall him mentioning the lift was only 30mm, with the other 30mm coming from the larger tyres.
Just finished watching that video. The guy from black sheep said the rear door tyre relocator was good for fitting 35 inch tyres. However they can only fit 33’s in Sweden. Big
Bigleonski was correct. 30 mm suspension lift and 30 mm with tyres. The modification that caught my eye was portals but the price 🤢 approx €40000
