Battery L/H Drive
Steve A
4:55 PM
Grapevine, TX, USA
I have some questions about the battery compartment.
In the picture below with the yellow and orange circles, why is there nothing attached to the negative post? What is the item in the orange circle supposed to go to?
In the other picture that is just the aera for the fuses?
Where would the 2nd battery go?
landmannnn
10:55 PM
Guessing not your vehicle, the negative terminal has been disconnected (as per your circles).
The starter battery lives in front of that fusebox, the secondary battery when fitted is mounted on the right hand side as per the second photograph.
Steve A
4:55 PM
Grapevine, TX, USA
It is my Trialmaster, I have had it for about 3 months, do these batteries have more than 1 set of + and - terminals?
landmannnn
10:55 PM
No, just a normal pair of terminals.
I can't imagine why the starter battery has been disconnected.
anand
5:55 PM
Maryland
That is the aux (second) battery.... but that cable should definitely be connected as the battery is doing nothing right now
anand
5:55 PM
Maryland
Second battery is just dead weight in this case. I would say, get that back to the dealer. Somebody had one job…..
Absolutely correct; it's literally the second item under "Inside vehicle check" on the PDI...
Steve A
4:55 PM
Grapevine, TX, USA
I found the start battery, it is hidden under a plastic cover. see yellow box
I called the dealer but got his voice mail so left him a messagek
Thanks guys
