C'est du plagiat d'un certain Largo WinchTop !!!!
I measured the grill itself, the opening is slightly larger of course:@Jean Mercier Could you please do me a favor and measure the lowest opening in the grill the next time you get your hands on your car? As shown in the attachment.
Thank you very much...
OK, next time I measure the opening, but it will be very tight I guess or 2mm to small!Those: https://strandseurope.com/product/siberia-sr-led-bar-12/ are 45mm high... Hmmmmm...
Are you sure?I measured the grill itself, the opening is slightly larger of course:
This would fit in that hole quite nicely, its E marked so road legal on main beam...I measured the grill itself, the opening is slightly larger of course:
Euh, now that you make the comment, hmm, perhaps I made a mistake! I'll measure it again, or somebody elseAre you sure?
360mm seems small
Yeah I was wondering that. However mounting forward of the opening on the massive Euro bumper “may” still allow enough air in. Won’t work for me though as I’ve the winch optioned, unless I want to add to the faff of accessing it which I don’t.you want to close an opening that was made to supply air?![]()
I set the measures in relation. You wrote that the grill ist about 40 mm high. That gives a ration of about 1:3.75... Which means the grill is about 750mm wide... And regarding the relation between the grill and the width of the car, that makes more sense...Euh, now that you make the comment, hmm, perhaps I made a mistake! I'll measure it again, or somebody else
Perhaps it was 56 cm.
Maybe next visit you can get a few photos?Yes, I guess so, but I didn't analyse how they are mounted. I didn't like it at all! I would guess that they will not survive intensive usage, neither 10 years, but I could be wrong.
