Aux power points
Woody89
7:59 AM
England
Hi can anyone shed some light on where the aux power points are on a utility wagon. I under stand that there is 1 in each footwell and one in the back somewhere
Cheers
The search feature is awesome tool. Many walk through on where everything is and how hook it up.
I did that and it just came up with the high load switches I just have the standard ones could you tag me in the video
Cheers
The link below gives good information on the location of the footwell cables. The search function is good but there is so much on the forum now it can be a bit difficult to filter.
Thread 'Auxiliary USB charging point in auxiliary footwell power point'
https://www.theineosforum.com/threa...t-in-auxiliary-footwell-power-point.12412359/
This thread has fuse information, including footwell fuses here.
Some people have crimped Deutsch DTP plugs on the footwell wire ends, DTP plug information is here. You can use a Deutsch DT plug for the footwell's 10 amp circuit, rather than the higher rated Deutsch DTP plug (25 amp rating) if you wish.
Rear power circuit (wire ends) are near aux battery postilion.
Cheers for this also do any of you know where the one is under the bonnet ?
Thanks everyone for you help found them and got sorted 👍
There are two circuits under the bonnet (both wire ends).
The wires are near the airbox on a RHD car. The wire ends are taped in a shiny tape, whereas the other cables have mat black tape..
Here are images from under the bonnet of a left hand drive INEOS. Deutsch DTP plugs have been fitted to the wire ends in these mages.
On my truck I didn’t opted for the extra high load switch panel does any one know of the wires are there ready and has anyone brought the switch panel after to fit it their self ?
The extra wire ends come with the aux power option. If you did not choose that option, you do not have the extra power circuits.
Hello everyone, could someone please help point out where is the best location to tap power for an under seat subwoofer, it requires 10 amps but a 15 amp or more source should be enough. Fuse box photo attached, thanks in advance.
Does your car have the aux power option. If yes, look for the 40 amp wire ends in the battery bay and change the fuse from 40 amps down to 15 amps.
Does your car ahve the aux power option. If yes, look for the 40 amp wire ends in the battery bay and chnage the fuse from 40 amps down to 15 amps.
Hello,
No I have just one battery in my vehicle, i am wondering if the missing fuses ( water separator water pump used for diesel engine) can be used.)
