Always same problem no high to low transfer gear
Leonidas
10:11 AM
UK
I have read most of the posts on the subject and tried every possible avenue , but no way!
When delivered my Grenadier had the gear lever pin out issue.Dealer replaced the Bowden cable.
After that ,I could lock the transfer case, no problem
But impossible to move from high to low either on locked or unlocked.I have extensively tried today in fields for the first time
Many comments recommend to apply some force, but I am a bit loath to do that.My maximum pull has been about 10 kg
Should it be more or back to the dealer?
Would you have another trick not discussed yet?
It's a deliberate action going from 4H to 4L but not significantly more than locking the center diff. Assuming you know to be in neutral and have read the manual then I'd put it on the dealer to resolve. Especially since you mentioned the dealer replaced the cable. If that's not an option get under it and have someone operate the transfer case shifter to see if it's obstructed. If you haven't used something to keep the shift collar pin retained confirm it's still there.
Also try rolling the truck forward just little bit, then you can pull the lever back, some time you need to help mesh the gears, again put it in neutral before changing range.
From the manual
"The center differential can be locked and unlocked with the transfer case selector while on the move so long as the axles are rotating at the same speed. Range changes require shifting to N (Neutral) on the automatic transmission.
In some cases, shifting range with the transfer case selector can be difficult. Do not force it. Allow the Grenadier to roll forward a few inches to allow the internal mechanisms to align and attempt shifting again.
To shift the transfer case range:
1. Bring your Grenadier to a complete stop and continue to hold the brake pedal.
2. Shift the gear selector to N (Neutral).
3. Lift and hold the locking collar on the transfer case selector and shift it to the desired range position."
Good idea, I'll get under tomorrow
From the manual
Thanks for your response
Done all the points you kindly mention
I'll try on a slope tomorrow
From the manual
You have made my day!
What it needed is a bit more slope than I had done before
All ok when doing that
Many thanks
Sometimes a little bit of steering lock helps too. If you are in a dead straight line the gears may not line up. I know this from experience!
Usually mine goes in no problem, maybe one in 10 it needs a roll.
I'll try that as well
Many thanks
I’ve been having the same problem and took mine to the dealer last week. I just got a call today that they are replacing the transfer case.
It sounds like yours is working normally now though! Congrats!
Lucky this time! Wait til next🙂
Any idea of what the problem is with yours?
