- Local time
- 11:20 AM
- Joined
- Mar 9, 2022
- Messages
- 503
It doesn’t take much. You can see a 1k swing pretty regularly throughout the year.If it is barometric how is it showing below sea level. That would be one hell of an atmospheric pressure.
well, 70ft underwater would be 2 atm. I hope the barometer isn't off that muchIt doesn’t take much. You can see a 1k swing pretty regularly throughout the year.
According to mine, I live about 4 meters below sea level...
I have a similar problem with the altimeter showing that I'm living 120 ft below sea level. I live approximately 500 meters from the sea on the South Coast of UK. I have my car booked in for some warranty work in January and I will add the altimeter problem to the list.Living in New Orleans I expect to see negative numbers, but the city isn't 70' below sea level.
Should be showing around 8-10' above sea level where it sits.
Anyone know of an issue or is this just a limitation of altimeters in vehicles that I have to live with?
Ineos Grenadier overhead switches 3.0?Well Houston today was 30.40 on the altimeter. I’m currently at 36,000ft and up here we use standard of 29.92. So that’s 480ft difference on gauge.
Also for people complaining about the buttons being overhead and it being a distraction….
wait, I feel like I am missing out.. where is/was "2.0" (or 1.0) ;pIneos Grenadier overhead switches 3.0?![]()
That's my understanding also using GPS triangulation. I believe the compass/ altimeter is a repeater for the GPS data the Pathfinder feature uses. In my experience if Pathfinder is not working then the compass is not working either. I think the hardware is probably ok because it does work sometimes.It's definitely working ok on mine and after the s/w update so are the pitch and yaw readings. I always thought the elevation was done using GPS?
The same has been said about the driver.If the device is going to so inaccurate, why even put it in the vehicle?
That’s actually a great idea. Ineos should parter with Bremont, CWC, or some other British watch brand. I’ll mention the brand Christopher Ward, but I’m assuming Sir Jim wouldn’t want some other blokes name in this vehicleYep. I would be happy with a nice analog clock. It could be broken but still be correct twice a day. That would be an improvement on the compass.
