Agile Off Road IOBOX Performance Tuner
Does the pedal tuner work in reverse? That would not be a good thing.
The Pedal tuner works in a very natural way. I use economy #4, I don't have much mileage, Under 300 miles. I use the Pedal and Tiner from IOBox. Reverse seems nornal, nothing different about it.
I installed the unit that Owl sells. Pedal Control.
I just keep it in Eco mode. It was an impulse buy while waiting at Owl.
Ok... So I installed this and got a check engine light with the following codes (see picture). I rechecked all connections and may have reversed one. Even after verifying all connections I could not get them to clear for long by clearing the ecm faults with my reader. I put everything back to stock and still can't get them to clear. So at this point I am trying to figure out if the car just needs a min to realize that it is back to stock, I connected a stock connector wrong, or there really is not issue but only the dealer can clear the code. The car runs 100% fine. Just posting here in case anyone else has run into this and has advise.
Did you do the tuner? I assume your not getting faults from the pedal controller.
Yes the IOBOX. Sorry should have specified.
You have the cam position sensor plugged in backwards to the IOBOX harness (P0367)... When you are clearing codes make sure the engine isn't running.
