300w inverter retrofitted - how I did it.
landmannnn
9:38 PM
I know several threads on this, but since most seem to be lengthy debates on P=IV, power factors etc, I thought I would write up my fit.
I bought a 300w pure sine wave inverter, branded Bestek.. I bench tested it and it seemed to be able to power things around that power.
I've popped out the on/off switch, more about that later.
Next I removed the rear left panel in my IG. A surprising amount of space, I reckon you could fit a tyre compressor in there!
So now a trial fit, no clearance issues at all.
Power taken from the underseat busbar
Wired up.
What I did was to replace the little on/off switch with a relay powered by the 12v socket. I also added a a panel on/off switch in series with that 12v supply.
That means the inverter can only run with the engine (or aux switch) on and the switch on.
So I can't run the battery flat and if the inverter is not being used it won't be running on idle.
[Continued next post]
For the mains socket I plugged into the inverter and used a remote socket.
Here it is almost complete. I toyed with putting the mains socket in the factory position, but since I found one with a great colour match, it went more visibly.
I will add a European 2 pin socket when I am next there, I think I saw some grey ones in the local french Brico.
I hope this helps somebody!
Edit - a few other thoughts
It appears the factory panel has an air vent. As there is plenty of space and gaps I am pretty sure there is no need for a 300w inverter. It has thermal protection should that be an issue.
Why 300w? Enough to power a fridge, laptop or drill battery. I couldn't think of anything I needed to power that justified something bigger.
USB. The inverter has USB outlets, I could have extended them to a panel mount. Maybe I will do that if I find I want USB in the cargo area.
There is a socket used by the factory inverter, presumably to turn it on/off. Probing it, it seems to be about 2v, so likely as not it is controlled via canbus to the body control module, so I ignored it.
Past experience tells me that spade crimp connectors are not suitable in automotive environments, so all connections were soldered and heatshrinked. I wrapped all the wiring in cloth tape so it is quite close to factory.
Hello all
I cannot get power out of my factory installed 400 W inverter......is there a fuse. i could not found it on any of the fusebox diagrams
Hello all
The inverter is fused at the busbar (and is not on any fuse diagram). I will find the link.
EDIT: Look here, at the ZCASE MEGA fuse labelled 4 on the 7 stud busbar. The image shows that slot empty (image from my AU diesel spec car), but it is used for inverters in the US, and probably Canada. The provided link also provides much more info on the Grenadier's busbars.
Also download a copy of the Rok Dr Guide, which has much more fuse information than the INEOS fuse diagrams alone. There is also a thread on fuses here.
7-stud-busbar-au-dx-jpg.7843521
Hello all
Just a double check, it only works with the engine on or the Aux switched on.
