1 inch front coil spring spacer
ORSO
4:03 AM
Italy
Got the spacers from Shadowmarq in today. I’ll have to find some time and get them on. Should give about 1 1/4” upfront and get rid of at least half the factory rake and a little extra clearance for the larger tires without the risk of the 1.7” or 2.5” spring lift. Figured I would give this a try until a proper lift with adjustable CAs and properly sized shocks is available.
would you be able to measure the inside and outside diameter of the spacers?
Thanks!
