Wolfbox problem - seeking ideas or knowledge….
Coullabus
Forum Donor
12:03 PM
Isle of Islay, Scotland.
I had my Wolfbox 900 fitted professionally almost two weeks ago. All worked well until…. Today, out of the blue, after hitching a trailer, it suddenly switched to split screen. Then forward only. I have reset it to rear view a number of times, but after a few minutes it switches back to forward view, occasionally Split View.
This is happening regardless of towing, or not towing. It becomes dangerous when you check your mirror to see what is behind you and see nothing, despite the car behind.
Anyone else experience this? If so, what’s the solution?
Check your firmware version, all I can attest too is all my issues went away when I updated to the latest. Though I never had that problem before to be honest.
Thanks - showing my ignorance, how did you do the update?
You can access the latest UK firmware here. The instructions are at the bottom of the page.
You will need access to a PC or laptop with a micro SD card reader (or a USB adapter) to do the update.
I have just been through an issue with my G900 and I have to say the support from Wolfbox was outstanding.
