Using a strand SIBERIA XP - Wire routing from front right roof outlet to roof centre console
Pat-Ard
Global Grenadier #00520
8:39 PM
Hi folks,
is it necessary to remove the the roof liner to route a cable from the front right roof outlet to the roof center console?
I‘d like to add a led bar to the roof, but the new Strands Siberia XP comes with two switches, which I‘d like to place some where in the roof centre console.
Hi folks,
The right roof connector is already run to the switch. The switch turns on power to the light. If your light bar has an extra switch and you want to use that as a control then you will need to mount that somewhere. I assume the two switches are related to different light patterns/colors?
@ADVAW8S Yes, I know, the richt outlet has it's own switch, but the Siberia XP has two separate switches to control the light output and the second for the color of the day light driven light.
Hi folks,
so my new thoughts... I want to use the EXT1 only for switching between high beam an low beam for the strand Siberia. Should this work, if I connect the grey cable to the positive cable of the EXT1 switch?
