water infiltration from the roof
ORSO
3:20 AM
Italy
after washing the car I noticed that there are two water leaks on the back of the trunk. one right and one left.
I assume they come from the fixing screws of the external handles on the roof.
any experience or advice?
thanks
  • Sad
Reactions: IGL
I wouldn't assume. I'd cover the screws with tape and try again.
I tried adding some additional rubber seals and it seems to work
Hi @ORSO
You say additional rubber seals. Were there any seals fitted previously?
I noted when I had some of those screws out to attach auxiliary lights there were dimpled rubber seals under the screw heads. In one location the seal was missing.
I wet-installed everything with a low grade black silicon sealant to ensure it was water tight and I haven't noticed any leaks.
Hi @ORSO
I wet-installed everything with a low grade black silicon sealant to ensure it was water tight and I haven't noticed any leaks.View attachment 7850862
Hi Clark Kent, That light looks nice. Who makes it?
DaBull
DaBull
Hi @DaBull Thanks for your regular contributions to the forum. I hope you're enjoying your vehicle.
That's an ARB Base Rack Auxiliary 10W LED. I posted about it over here. Should be available from ARB USA. Scroll to post #10 of that thread to see some action pics. I liked this light because it mounts over the rail bracket and doesn't need a tube clamp. The ARB-supplied plugs need to be swapped over to DTP to connect to the roof outlets.
Hi Clark Kent, Thank You!
DaBull
