UK & Ireland Vision x lights
Mole75
6:36 AM
UK
Has anyone had any issues fitting the vision x lights….. I have fitted the new aux lights using the original ineos wiring loom so that when the overhead switch is on the lights should come on when main beam selected. All that happens is they come on for two seconds then go out, high beam stays on. I had to change the connectors on the ineos wiring loom to fit with the vision x lights, and adjust the housing in the front grill. I have not used the wiring loom that came with the lights, or changed any relays, as thought they were more or less plug and play. I have tested the new lights with the supplied wiring loom on a battery and lights work fine.
