Vision X lights front grill
Mole75
4:44 PM
UK
Has anyone had issues fitting vision X lights
Was told they were plug and play with only a small adaption to the original housing needed….did this fit fine, had to swap connectors on the original wiring loom to fit new lights. When turned on using overhead switch and main beam lights come on for 2 seconds then off main beam stays on. Electrics not my thing does the relay need changing? Did try them with supplied wiring loom on spare 12v battery and worked fine.
