UHF Antenna Cable from Roof Rack
Chook
1:37 PM
Brisbane QLD, Australia
With one of the factory options being a fold down UHF Aerial Mount on the Roof Rack just wondering if anyone has this fitted and where they bring the Antenna cable through the roof ????? (Grenadier - no auxiliary power outlets on roof)
Having no roof rack, I clamped a fold-down UHF Antenna mount to the top rung of the ladder and then ran the cable down the left side of the ladder and under the bottom of the 30% rear door. No holes were required.
An option might be as follows: Remove a tie-down bar above the gutter, and then the black composite concave insert behind it. Under the insert there may be holes already in the structure. If so you could drill the composite and feed your UHF cable through a grommet ....then run the cable down the B pillar.... Essentially that's all there is to the vehicles fitted with external power outlets....
