TransferBox Oil cooler
7:04 PM
Looks like they have an oil cooler/pump fitted to the Grenadier in SA
Marco 12v pump
In the video from South Africa, that drain plug and the hose are completely exposed under the vehicle. See the screen shot I took from the video below. I'm going to assume that this is not how it will look in the production-version of the vehicle...
That was not fitted to the 2b vehicle I saw Monday morning.Judging by the other engineering that is on the vehicle if they were installing a pump as above they would do a better job than that. At least one would hope so.
A banjo bolt at the most vulnerable part of the assembly is not the best idea in the world.
But I’ve had some pretty bad ideas over the years ?
I’ll just put this down to data analysis on INEOS part.
but good spot.  Countyv8
Someone said they had early issue with transfer case overheating and that they were looking into a cooler for some sort of “tow package”
That would make sense. Well at least they are trying to cone up with solutions and that has to be a good thing.
