Hi SteveThis will be the SOS call system, unsure how it will work exactly in the Grenadier but in every BMW if an accident occurs it will automatically call you in the car to see if you need emergency services.
If you don't answer them back then they will automatically inform emergency services of your location so they can respond.
You can press the button manually to call yourself.
The tracking side of things will only be transmitted once pressed or activated via an accident. This is how it works on a BMW, as I say not sure if it's the same in the Grenadier but I can't see it being massively different.
Why would you want to disable it?Hi Steve
Regarding the emergency call function MW and Porsche will disable the function for you if you don't want it
I don't want a SIM which I have no control of in the vehicle. BMW will remove the function iii you ask them you work for a BMW dealer .Why would you want to disable it?
I do work for a BMW dealer yes, but I've never had anyone ask for the function to be turned off that's all.I don't want a SIM which I have no control of in the vehicle. BMW will remove the function iii you ask them you work for a BMW dealer .
What are you getting up to that you you need to control/disable your phone sims????I don't want a SIM which I have no control of in the vehicle. BMW will remove the function iii you ask them you work for a BMW dealer .
It's not what Im getting up toWhat are you getting up to that you you need to control/disable your phone sims????
