Tow Ball Mounting Dims?
255/85
Forum Donor
2:32 AM
Western U.S.
Can someone provide the mounting bolt pattern on the frame where the tow receiver would normally mount? Also could use the bolt size. I'm assuming there are captive nuts. We haven't ordered the Tow Hitch and are thinking up other uses for the mounting points if we choose not to add it at some later point. TIA.
Distance between mounting holes on the tow bracket. Assume they are the same on the vehicle frame.
Vertical C to C = 2.75"/69.5mm
Horizontal C to C = 6.72"/170.7mm
Added to eliminate a dead end.
Bolt size
M16x40 1.50 thread pitch
We have the hitch for sale. 350.00
4 bolts , flat & lock washers 13.50
We picked up one from the dealer. It was the simplest option.
Place an ad in Classifieds section.
