Torx Screw - Front Headlight Cover
DVA Mechanics
Supporting Vendor
2:06 AM
Atlanta, GA, USA
Hi all - does anyone know the specification for the Torx screw that holds on front headlight cover on? I was installing an accessory headlight cover today and stripped one. Thanks!
Hi elderderek, The reason it may have stripped may be because the screw needs a Tork + (PLUS) driver bit.
The Grenadier has both regular Tork Screws and Tork + (PLUS) screws.
If you find your driver is a bit loose in the screw, then it may be because the screw has a Tork + screw head and you are using a regular Tork Bit Driver.
Here's a youtube video to explain the differences. DaBull
View: https://www.youtube.com/watch?v=U27j1ZvaWeU
Hi mate, just came across this post. Did you have any luck tracking the spec down?
No, I couldn't even successfully drill it out. I took it to the dealer and they got it out for me, but didn't have a replacement screw, so I still need to find one!
