Sprinter Steel Wheels 17"
9:33 AM
Donegal
A9074016000 is a parts no with Mercedes for their 17" steel wheels 6x130. The manufacturers are Sudrad or Kronprinz and thus available aftermarket. Problem is, quite often your tire dealer is unable to find/order them w the manufacturers. Dunno why that is, even with the orig manufacturers number they cannot be obtained. You do get them aftermarket with various suppliers, however, but check carefully, sometimes they are more expensive aftermarket than with Mercedes.
I’m looking into these most likely. 3300 lbs load rating should be acceptable.
Bumping this thread back to the top.
Has anyone on the forum, in the US or Canada, been able to put hands on the 17” Mercedes steel wheel we keep hearing about?
Have spoken with several Mercedes parts specialists and gotten nowhere.
Hi, the wheel can be ordered with any genuine Mercedes dealer, all you need is the part no. Aftermarket can be difficult. US might be slightly different since the Sprinter is not a Mercedes over there. A Freightliner, no..?..Maybe they got their own parts no system. A Sprinter dealer should be able to pick the wheel from a list w/o the parts no.
Sometimes you find them on eBay:
Best of luck. Frank
Did you reach out to Warner? They're the IA dealer in Utah who also have a van/Sprinter division.
Taking the part number from @frankkk 's post, it shows as a valid part number through a number of online MB dealer parts departments.
As @Krabby said, I would reach out to @INEOS-Warner as they have a Sprinter dealer as well.
