okay so my speedometer is off by about 2.5 mph. Could this bad calibration also impact the odometer and thereby the range guess-o-meter?
I'm not sure what the story is in the States, but as far as I know everywhere else the speedo is always higher than real speed checked via a gps.okay so my speedometer is off by about 2.5 mph. Could this bad calibration also impact the odometer and thereby the range guess-o-meter?
My gren reads 105km/hr when the GPS speed is 100km/hr. This was exactly the same on every 4wd/car I have had before it. Toyota's tend to be 104km v 100km. Legislated in Australia, conservative margin for error.
With 33" tyres my speedos have read 100 v 100 in the past.
Hopefully it keeps the mileage low to protect resale...But getting back to the OP - does this built in difference affect the calculated mileage?
I think it would do the opposite TBH.Hopefully it keeps the mileage low to protect resale...![]()
that is what got me wondering as far as it impacts how the vehicle reports MPG. my calculated mileage is lower that what the grenny says. if the odometer is off the same % as the speedo that might be part of the reason for the optimistic calculation by the vehicle.But getting back to the OP - does this built in difference affect the calculated mileage?
Same reason most vehicles in general show a higher speed than actual and also report higher MPG than actualthat is what got me wondering as far as it impacts how the vehicle reports MPG. my calculated mileage is lower that what the grenny says. if the odometer is off the same % as the speedo that might be part of the reason for the optimistic calculation by the vehicle.
Australian laws require the odometer to be accurate within 4% and the speedo to read zero per cent under to 10 per cent above the actual speed, so manufacturers typically set it at about five per cent over
- So just to clarify from this thread, bigger tires correct the speedo and mpg calculations (up to a certain size)?
- What about the ODO? Is it currently accurate or will it be corrected by bigger tires?
There's nothing to resolve, this is common on many (or most) modern vehiclesI didn't see these messages before I took my Grenadier in for service today (installation of the tow package and other options). On my way to the dealer (RDS in Pennsylvania), I did notice a 2-4 mph difference from what was displaced internally vs. my GPS. I added this to the list when I dropped-off my vehicle, but it sounds like this is not something that will be resolved.
Yeah I tested this awhile ago and speedo was 104km and GPS was 100km after 6kms of pretty flat highway travel using cruise control. After 6kms though my foot got cramped from the footwell intrusion and my back was out from the lack of lumbar support!I'm not sure what the story is in the States, but as far as I know everywhere else the speedo is always higher than real speed checked via a gps.
Same here.I have noticed that at lower speeds (<45 mph) the difference is about 1-2 mph while at highway speeds (55-85 mph) it is 3 mph off based on GPS speed
