So how does this switching work via the can bus?
The key to the install appears to be the gasket, how do you think they made it? Is it cut down from a larger piece of rubber, a glued linear strip (looks like a join at the top) or 3D printed from TPU? Would TPU be robust and last in this location where its going to be hit with moisture and other crud regularly?
i am debating on doing something similar but keeping all the original wiring ( not a fun of cutting original plugs off ) i am struggling to find the actual power rating of the ax lights and the fuse they are powered from . Anyone has any ideas?
I like the mount of the light bar, but it needs drilling...
