Snorkle delete instructions
CABluey1
Forum Donor
2:43 AM
California, USA
Does anyone have any instructions on how tp delete the factory snorkle? I have taken the snorkle off but have difficulty removing side marker light. The plug is inset so its hard to disconnect.
I’m pretty sure it twists and pulls out, bayonet style..
They are tight, I know that once out they are hard to put back properly. Many early cars had them falling out including mine because that hadn’t been put in properly… I think I have a spare side cover, I’ll take some pics of the inside so that you can see how they fit.
Does anyone have any instructions on how tp delete the factory snorkle? I have taken the snorkel off but have difficulty removing side marker light. The plug is inset so its hard to disconnect.
1. It is a Raised Air Intake. It will NOT prevent water ingress.
2. attached panel instructions. (Will add RAI if I can re-locate). Pay attention to the bottom two bolts/pins. You must TURN the signal light to remove/attach.
