Ski rack on ladder
Paco Garcia
Local Group Moderator
7:44 PM
Valencia (España)
Hello friends, taking advantage of some things I had at home, some supports from the Chinese, I started to make some ski racks and in my humble opinion it turned out quite decent. I detail the steps in case you decide, super simple and very economical.
- Clamps / Supports 6, €10 on Aliexpres
- Basket to support the Skis made of 2 mm iron that was at home, I just had to fold it.
Ski attachments €37 per pair en Amazon
I have 4 units to spare (I repeated the purchase) if anyone is interested we will surely reach an agreement
two 30 cm pieces of rail left over from a previous project
Some metric 10 screws, a little spray paint for the rails
and a couple of hours of work.
And this is the result:
Well friends, I hope you liked it and if you have any questions, don't be shy to ask. Greetings Paco
View attachment 7841336View attachment 7841340
View attachment 7841341View attachment 7841342
View attachment 7841347View attachment 7841348View attachment 7841349
View attachment 7841350View attachment 7841351View attachment 7841352
Great! I am thinking about the same solution and ordered clams so far.
Now I have some more ideas to finish the work.
For me the basket should be as deep as possible to ensure that the tips of the ski do not show over the edge of the roof.
How many cm do you have from the bottom o the basket to the roof with your solution?
Regards
bemax
Regards
bemax
Hello Bemax, from the bottom of the basket to the edge of the ceiling (without Protruding) I have 120 cm, you could still lower the bottom of the basket up to 10 cm more, but you would have the risk that when opening the small door you would have to be careful To avoid touching the corner of the rear bumper, the corner is higher than the center of the bumper. Greetings Paco
Regards
bemax
To give you an idea of "how much" they protrude from the ceiling, 150 cm skis
Thanks for the picture!
Unfortunately my ski will be at 170 cm. So I have to find a way to bring them down twenty to thirty cm.
Thinking about what you propose, if you do something similar to what I did, the solution can be quite simple, you have to take into account:
- from the base of the rear bumper to the roof line you have 129 cm
- with my type of solution the support tray needs 8 cm of
separation of the line from the step to be aligned with the
fixation.
- with those 8 cm the tray remains slightly behind the
bumper but without exceeding the line marked by the wheel
spare, therefore you can lower the basket from the
separation supports with some type of plate (yellow lines)
I don't know if that will be enough for you, of course they will have to stick something out from the top or the basket will be very close to the ground. Greetings Paco
Pensando en lo que planteas, si haces algo parecido a lo que yo hice, la solución puede ser bastante sencilla, tienes que tener en cuenta:
- de la base del paragolpes trasero a la linea de techo tienes 129 cm
- con mi tipo de solución la bandeja de apoyo necesita 8 cm de
separacion de la linea del del escalon para quedar alineado con la
fijación.
- con esos 8 cm la bandeja se queda ligeramente por detras del
paragolpes pero sin sobrepasar la linea que marca la rueda de
repuesto, por lo tanto puedes hacer descender la cesta desde los
soportes de separación con algun tipo de platina (lineas amarillas)
No se si con eso te sera sufiente, desde luego sobresalir algo por arriba tendran que hacerlo o la cesta quedara muy cerca del suelo. Saludos Paco
fixation.
fijación.
Muchas gracias por tu ideas!
Eso es la manera para hacerlo que yo he pensando tambien.
Con tu photo y las lineas mi decision es quasi tomado.
Esperero que mi entiendes, no he escrito mucho en espanol dessert hace mi semester de Erasmus in Toledo un cuarto de siglo antes.
Te expresas perfectamente en Español, yo lo hago en ingles a través de Google :Frío:, los idiomas no son mi fuerte 🤷‍♂️, yo termine la Uni hace un poco mas de tiempo algo así como 42 años, la única ventaja de esto es que ya estoy Jubilado 😁. Me alegra haber despejado tus dudas. Saludos Paco
has anyone tried something like this
or this
