Screen display reversed
Mudnut
Quartermaster Owner
9:21 PM
Clifton Beach QLD, Australia
Hope this is only a temporary glitch. Reversed screen display. First thought missing driver info, then realized screen reversed.
Hope this is only a temporary glitch. Reversed screen display. First thought missing driver info, then realized screen reversed. View attachment 7887106
Not uncommon. Sorts itself out fairly quickly. I thought the last head unit update had a fix for that in software version xxx2940. I haven't had that glitch for quite a while.
Screen is fine. Someone moved your steering wheel to the wrong side, though.
Ha Ha. I learned to drive in the Bahamas, which also drives on the correct side of the road, and in a left hand drive car. Was OK until you needed to pass a large vehicle. I remember leaning over almost to the RHS window to see if it was safe to pass.
Mine did that, turned it off, waited until all the noises stopped and car had finally gone to sleep, turned back on and not done it since 🤞(early December)
