Removing/Reinstalling Driver Seat
DG3
1:04 PM
Florida, USA
After an 8 week wait, my Black Sheep seat safe is scheduled to arrive tomorrow! Have any of you removed and reinstalled the driver seat? Any guidance or gotchas would be appreciated.
Wiring connections are straight forward under the seat; and to pull the seat itself, it is 4 bolts. Also, make sure the battery is disconnected.
Do not move or Drive the vehicle with the seat out and battery connected ! as happened with mine whilst in an African workshop this will cause seatbelt error warnings that need a main dealer with relevant kit and software to sort out. It was only moved/driven a few metres in the workshop with the seat out and it played havoc with the warning lights and sounds until I could get to a dealer who could update the software. 👍🏼
Will the error occur if the battery has been disconnected for 15 mins? I am asking because I would like to remove the drivers seat. However I am afraid of triggering any errors that cannot be erased without the dealer.
What happens if this isn't done?
Depends on what is done on the car, but if you are doing electrical work, you can get errors, sometimes quite a few (requiring the dealer to clear them). There are a few threads on the forum talking about these.
Hey guys, do you know if the same procedure (disconnecting the battery) is needed as well when removing the front passenger seat?
Thanks
Laurent
If you are just tilting the seat back and not disconnecting any of the wiring underneath, I do not think you would need to disconnect the battery. I recently installed Owl's under seat ARB air compressor kit and while I needed to disconnect the battery to connect the air compressor, I do not think I would have needed to do so to install something like Black Sheep's cubby safe. See Owl's video below:
