Remove roof rack rail
Christian
11:18 AM
Freiburg im Breisgau
Has anyone removed these roof rails yet? What's underneath?
How are they attached?
HI Christian, I have yet to see anyone on the forum post anything about removing the plastic roof rails. I do remember watching some Ineos Factory videos and it appears that each strip is held in place by 4-5 metal studs that are affixed to the roof and protrude upwards approximately 10-18mm (1/2" - 3/4"). My assumption is that these roof rails are a simple press fit onto these protruding studs. You could try sliding a thin piece of fishing line underneath the strip and pulling it along until you reach a stud and then use a thin plastic trim removal tool to try and lever it up off the roof a bit and repeat this until the whole strip is up and removed. I don't think there are any clips involved, however I am not sure. If you do remove the strips, perhaps take some measurements on where the studs are located along with photos of them and how the bottom of the strips look too. DaBull
I remember a thread where someone was missing one of the roof rub rails on delivery, check it out as it may give you more details
found thread
Here
I began by prying them upward at what appeared to be the location of the metal “studs”. I used a plastic shim, and some hand force. This seemed to work, then I discovered you can (with a bit of effort) slide the entire roof rail forward and the rail will slide off the plastic retainer piece that clips to the metal stud; leaving the plastic piece behind.
I’m a bit worried I may have damaged the plastic clip pieces a bit by the forceful prying, but think I’ll add some silicone or simple super glue when reattaching the plastic clip to the metal stud.
HI ScottAZ, I am going to be wrapping my Grenadier roof in Xpel Stealth satin/mat 7.5mill PPF wrap to protect it. If I read your post correctly, one should push the plastic strips forward and that will release the
plastic strip from the plastic clips which will remain on the stud posts. It appears it will then be easier to pull up the plastic clips with out damaging them, is that your take. How would you recommend installing the plastic strips again, put clips into plastic strips and then push them down onto roof. Any step by step recommendations would be appreciated. By the way, I was born in Chandler Arizona. DaBull
Hey DaBull! I’m actually a native Tempe/Chandler boy, didn’t move far, and our girls even went to the same high school I did. Kinda an anomaly in such a large city.
Our roof gets wrapped tomorrow……. Yes, I am suggesting you should be able to slide the roof rail strip forward to slide it off the plastic clips (so the plastic clip stays on the metal stud). It’ll take a bit of force; with 2 hands.
As of now, I am planning to put all the plastic clips back on the metal studs, and slide the rail back on. However, you have a good suggestion of putting all the plastic clips back on the rail piece and simply snapping it back in place on to the metal studs. I think that would work nicely, and minimize risk of damaging the wrap material. Tomorrow evening, when the wrap is done, I’ll try both scenarios and post an update.
The original “prying” did work, but I did damage a couple of the “legs” on the plastic rail that slide over the plastic clips, as well as some of the “teeth” on the clip piece. So, if you end up prying the rail strip off, take a little extra care. It’s difficult to show in a picture, but the left side of this u-shape (part of the rail piece, and the part that slides over the plastic clip) is actually loose/damaged and kinda “flapping in the wind”, although the right side is perfectly in tact still.
Hi ScottnAZ, Thanks for the extra info and photos. Let me know how your wrap goes and how you get the strips back on.
What type and color wrap are your going with?
DaBull
DaBull
We’re wrapping the roof in 3M white. Barby was able to find us an incoming unit that matched our original order perfectly with exception of the roof. I figured it was a small detail, and saved us a few months of waiting :)
Okay, I looked more closely at the rail before reinstallation, and the only way to remove and reinstall is to pry up and off, then snap back down in place. Reinstallation took less than a minute to pop all 4 back on.
If you look at the picture below, half of the u-shaped catch pieces are facing one direction and the other half facing the other direction. So, in theory, you could pry up to release 3 of the contact points and then slide it off the other 3, but frankly, take your time with a plastic shim or pry tool and you’ll be fine popping the piece off. Still shouldn’t take more than 5-10 minutes for removal.
As a side note, I also removed the safari windows to make the vinyl application easier for the installer.
Is the dealership doing that or you personally? What is the cost on that?
Is this question to me? Rusnak Ineos Delership provides the option to take care of a roof wrap (they have a catalog of add-on wrap and ppf options), but there is a local place who has wrapped and/or vinyl stickered all of our work trucks over the years, so I preferred to give them the business. I paid $900.
All of my roof rails are loose and rattle when I close the doors. Is there a way to tighten them?
Hi Shawnpalmer, Are you referring to the 4 plastic roof rails on top of the roof or the 4 aluminum grab bar tubes at the roof sides? The 4 plastic roof rails on the top of the roof do move around a bit, however I would be surprised that they would make any noise or rattle unless the screw posts that hold them to the roof are actually loose. I had my 4 plastic roof rails pulled up with trim tools to have my roof wrapped in Xpel Stealth Clear Matte PPF Film. In looking at the screw posts that hold the 4 plastic roof rails onto the roof, they are really secure and one would have to try to unscrew them to break them loose, I made sure my wrap company did not try to undo the screw posts as I did not want to break the paint film which sealed the screw post to the roof. I did not want to create a situation that might eventually lead to a leak. I once toyed with taking the 4 plastic roof strips off and then backfilling them with polyurethane caulk by using a putty knife, (you would need to keep the attachment points clear of the caulk), however quickly realized it would be a messy job. Instead I wrapped the roof to protect it. By wrapping it I don't have to worry about the 4 plastic strips rubbing on the paint as they now rest on the PPF film and the PPF Film also protects the paint as it will be a bit harder to wash the roof with the low profile Leitner Design rack I am installing. DaBull
I can't recall where I saw this done but be warned that the clips are single use "Christmas tree" type clips and may need to be replaced if the roof rails are pulled off. There are welded on round headed screws sticking out from the roof along the underside of each rail - 3 to 4 of them and pulling off the strips will most likely damage the clips.
The strips may have been removed previously and the connectors damaged. The clips can be replaced with new ones and the roof rails re-seated but they can't be adjusted.
This forum is great, it's got an answer to everything! My roof strips are a bit loose and rattly and I was concerned about them chaffing the paintwork over time, I was wondering if I could remove them and add some packing underneath and this was the info I was looking for. For those of you who have removed and re-fitted the strips, do you think I'd get away with fitting a small o-ring over the studs and then clipping the rails back on?
Hi G-Man, My solution was to install PPF Film on the whole roof. Roof Strips removved and then PPD film installed and then roof strips put back on. Protects against chaffing and protects the paint for 10+ years. A bit more expensive then your proposed solution. Perhaps just adding PPF strips a bit wider than roof strips would work.
Here was my solution.
DaBull
https://www.theineosforum.com/threads/show-us-your-wrap-and-window-tints.12415285/
