Does the main rear door have a wiper?
Well I suppose that’s almost a wiper, got about a quarter of it.View attachment 7795628
It appears that it does in this picture from the brochure.
My tyre has a bracket and a box over the top of it. I always use the side mirrors and no doubt will learn to use the camera thingy in the Gren.I wonder if a longer blade will work. You’re right, it won’t cover much.
Yep would work much better sitting top right hand corner.I wonder if a longer blade will work. You’re right, it won’t cover much.
Look at the photo above posted by @Inez ~ there's not much room for a longer blade.I wonder if a longer blade will work. You’re right, it won’t cover much.
Looking back through some older photos, your right there is no way you can fit a longer one with the motor in that location. Is there a rear screen wash, I presume so from earlier photos, is that going to have enough pressure to act in a similar manner to a head light washer, with out the forward motion effectLooking at photo you may get away with another 2". It is not helpful having the motor so far down in the bottom left. It will be interesting to see if a longer one is installed in production vehicle. I have only driven a PTO2 off road and on private estate roads for an hour in good weather and to be honest can't recall the rear view vision.
Yes the Countach always annoyed me when backing down my parent's long leafy drivewayI have driven so many vehicles that you can’t see out the back of that it isn’t going to be an issue
